Database error message when running the Script to add new records
  • 1.  Database error message when running the Script to add new records
    Posted 07-18-2023 05:14
    Hello all,
    I developed a script to either update an existing timesheet or add a new period of timesheet. In the script I convert all dates attributes into a string before to use them in the Set Where statement. BTY, the script is working but at  some point generate the following error because of "Adding records" and I don't know why ?
    Here is the complete script :
    from psdi.mbo import Mbo
    from java.util import Date
    from psdi.app.common import DateUtility
    from java.util.concurrent import TimeUnit
    from java.lang import Math
    from java.text import SimpleDateFormat
    from psdi.security import ConnectionKey
    from java.sql import Connection
    from java.sql import Statement
    from java.time.format import DateTimeFormatter
    from java.util import Date, Locale
    mAmsActions = MXServer.getMXServer().getMboSet("ZZAMSACTIONS", mbo.getUserInfo())
    maximo = MXServer.getMXServer()
    mUser = maximo.getUserInfo(user)
    mAmsActions.moveFirst()
    mGap = mAmsActions.getString("ACTIONS")
    mFrom = mAmsActions.getString("PERIOD_FROM")
    mFromDate = Date(mFrom)
    mTo = mAmsActions.getString("PERIOD_TO")
    mToDate = Date(mTo)
    mDept = mAmsActions.getString("DEPARTMENT")
    mVendor = mAmsActions.getString("COMPANY")
    mPunchin = mAmsActions.getString("PUNCH_IN")
    mPunchout = mAmsActions.getString("PUNCH_OUT")
    mFingerno = mAmsActions.getString("FINGERNO")
    mCal = Calendar.getInstance()
    mCurrDate = mCal.getTime()
    mCreatedate = str(mCurrDate)
    mCreateby = "maxadmin"
    mTS = MXServer.getMXServer().getMboSet("ZZAMSTIMECARD", mbo.getUserInfo())
    mEMPTBL = MXServer.getMXServer().getMboSet("ZZAMSEMP", mbo.getUserInfo())
    strt = Calendar.getInstance()
    end=Calendar.getInstance()
    startdt = mFromDate
    strt.setTime(startdt)
    enddt = mToDate
    end.setTime(enddt)
    enddt=end.getTime()
    mFingerno='5393'
    if mFingerno == '':
        errorgroup = "AMSTSCHANGENO"
        errorkey = "AMSTSCHANGENO"
        # Do it for all employee
        mEmptable = mEMPTBL.moveFirst()
        while mEmptable:
            mFingerno = mEMPTBL.getString("FINGERNO")
            mAmsActions.setValue("FINGERNO",mFingerno)
            mAct = mAmsActions.save()
            #mAmsActions.setValue("DEPARTMENT",str(strt.getTime().date()))
            while strt.getTime().before(enddt):
                mTsday = str(strt.getTime())
                mTS.setWhere("FINGERNO='" + mFingerno + "' and str(TS_DAY)='" + mTsday +"'");
                #mTSS = mTS.getMboSet("$NewWO","ZZAMSTIMECARD","FINGERNO='" + mFinger + "' and str(TS_DAY)='" + str(strt.getTime()) +"'");
                if mTS:
                    mTIMESHEET = mTS.add()
                    mTIMESHEET.setValue("TS_DAY",strt.getTime())
                    mTIMESHEET.setValue("FINGERNO",mFingerno)
                    mTIMESHEET.setValue("PUNCH_IN",mPunchin)
                    mTIMESHEET.setValue("PUNCH_OUT",mPunchout)
                    mTIMESHEET.setValue("GAP_ACTION",mGap)
                    mTIMESHEET.setValue("CREATE_DATE",mCreatedate)
                    mTIMESHEET.setValue("CREATED_BY",mCreateby)
                    mTIMESHEET.setValue("DESCRIPTION","*****************")
                else:
                    mTS.setValue("PUNCH_IN",mPunchin)
                    mTS.setValue("PUNCH_OUT",mPunchout)
                    mTS.setValue("GAP_ACTION",mGap)
                    mTS.setValue("CHANGE_DATE",mCreatedate)
                    mTS.setValue("CHANGE_BY",mCreateby)
                mTIMESHEET = mTS.save()
                strt.add(Calendar.DATE,1)
            mEmptable = mEMPTBL.moveNext()
    else:
        # Do it for one Employee (the one who is entered by the user)
            #mTSS = mTS.getMboSet("$NewWO","ZZAMSTIMECARD","FINGERNO='" + mFinger + "' and str(TS_DAY)='" + strt.getTime() +"'");
            if mTS:
            else:
    Mohammad Moula
    eSolution
  • 2.  RE: Database error message when running the Script to add new records
    Best Answer
    Posted 07-18-2023 06:23
    Please check if there is an unique index in this object ZZAMSTIMECARD in DB configuration app. That could be the reason which is validating the data before committing to DB.
    Subhransu Sekhar Sahoo
    Tata Consultancy Services
