  • 1.  Distinguish each MAS environment with env name.
    Posted 12-24-2025 12:11
    Is there any option to update environment name in StartCenter with color?
    Ex:-   When user login in MAS , he can be able to see environment name at header of startcenter like DEV/TEST etc with different color like below ?
    Thanks & Regards
    JustIn goodLuck
    ABS
  • 2.  RE: Distinguish each MAS environment with env name.
    Posted 12-29-2025 10:53
    If you're on MAS 9.0 or higher, and have system administrator access, you can follow steps here: Updating the user interface - IBM Documentation
    There are some things you can easily change such as logos, text for the environments, etc. and then there is the ability to override CSS to change the colors and such. This header example is in the documentation (though with a different color).
