  • 1.  Drill down on Failure Codes
    Posted 08-24-2023 18:05
    When at the Maximo World conference in the CMM course we discussed failure codes and drilling down deeper, i.e. not just and Oil Leak, but what part of the asset caused the Oil Leak.  We would like to implement this type of reporting in our work orders but all I see is the option to choose the Problem Code, but not the cause.  Does anyone have any suggestions on how to accomplish this in Maximo?  Thank you in advance.
  • 2.  RE: Drill down on Failure Codes
    Posted 08-24-2023 18:09
    Here is where I am trying to, not just select the problem/failure code, but go further by selecting the cause of the failure code.
  • 3.  RE: Drill down on Failure Codes
    Posted 08-25-2023 09:45
    Native Maximo functionality supports a Problem > Cause > Remedy hierarchy.  To insure relevancy, you can build a hierarchy for each type of Asset in the Failure Codes application (a compressor failure hierarchy will be different than a conveyor's, for example).
    Mack Parrott
