Empty PO XML Message received from the Oracle E-business Suite to Maximo
  • 1.  Empty PO XML Message received from the Oracle E-business Suite to Maximo
    Posted 02-04-2026 08:07
    Hello Experts,
    I am frequently facing the Oracle adapter integration issues coming from Oracle with an empty message like the following:
    <?xml version="1.0" encoding="UTF-8"?>
    <SyncMXPO xmlns="http://www.ibm.com/maximo" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" creationDateTime="2026-02-04T09:49:45+03:00" baseLanguage="EN" messageID="XXXXXXXXXXXXXXXXXXXXXXX">
      <MXPOSet>
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
        <PO action="" />
      </MXPOSet>
    </SyncMXPO>
    I want to figure out the root cause of this kind of issues in Integrations.
    Thank you in advanced.
    Oumayma Azouz
    AtkinsRealis
  • 2.  RE: Empty PO XML Message received from the Oracle E-business Suite to Maximo
    Posted 02-05-2026 09:11
    Hi Oumayma .
    you need to track the message back to the ORACLE system and see how the message changed as it went through the different operations.
    Did ORACLE send the empty message?
    If ORACLE sent an empty message then it suggests that the mechanism used to identify records to send is triggering on the wrong conditions.
    Did one of the earlier interface compoinents change it?
    It has been a long time since I worked on an ORACLE EBS interface problem.
    mark robbins
    Cohesive
