  • 1.  error Invalid Building
    Posted 07-24-2024 08:01
    hello everyone, when you enter work task tracking> select a work task> click change status, a dialog appears with the messages invalid building
    how to fix this one?
    Artyom Polyakov
    BF GROUP
  • 2.  RE: error Invalid Building
    Posted 07-24-2024 09:35
    Hi @Artyom Polyakov!
    I don't know "Work task tracking"... maybe it's a custom or maybe you mean "Work order tracking" or it could also be "Activities and tasks" (both applications have a change status). You must tell me exactly which application you are referring to. If it's your custom, I won't be able to help you.
  • 3.  RE: error Invalid Building
    Posted 07-26-2024 05:12
    I have a test max environment. if I come to "work order" > "work order tracking". I have the right window. like on the image.
    but custom
    I assume this is a custom dialog, I don't know where to find the settings for changing the links for the fields. i need your help.
    Artyom Polyakov
    BF GROUP
  • 4.  RE: error Invalid Building
    Posted 07-26-2024 09:01
    The first thing I see, that they are 2 different applications... they are not for the same object. "Work Order Tracking" works on the WORKORDER object and your custom app "Service Request (OIL SG)" is cloned from "Service Request" (I imagine that) that works on the SR object (SR is a view of the TICKET table). They are 2 different apps... yes?
    So, if you clone SR (which is working fine) and get SR (Oil SG) and use your CUSTOM app, it is not possible that it will not work well since it is a copy. Then, about your CUSTOM, what do you want to do with the status? or have you tried to make the application from zero? In any case, if you do it from zero, control field by field and compare SR(OIL) and SR to see the differences.... but it is much simpler to clone SR and then modify your custom app. Then, tell me what you want to do with the status of your CUSTOM and I will help you.
    To change "Change Status", with app designer in SR or SR (Oil SG), you can see in the image below: (what do you want to do there?)
  • 5.  RE: error Invalid Building
    Posted 07-29-2024 02:04
    Previously, "change status" in oil SG worked, but after restoring the maximo test server, this dialog broke. I need to restore this dialogue
    Artyom Polyakov
    BF GROUP
  • 6.  RE: error Invalid Building
    Posted 07-29-2024 08:57
    Hi!
    Do you have this app developmed (SR OIL) in PRODUCTION? It works well? Try exporting the application and importing it into your TEST environment.
    When we export and import databases, all the developments are lost... they must be saved beforehand.
  • 7.  RE: error Invalid Building
    Posted 07-26-2024 05:13
    I assume that this is a custom dialog, because after clicking on the link I get a normal window.  and I don't know where to find the settings for changing field links in the custom dialog
    should look like this
    Artyom Polyakov
    BF GROUP
  • 8.  RE: error Invalid Building
    Posted 07-29-2024 11:49
    Hi
    Invalid Binding mostly happen due to the relationship missing or wont get migrated properly since check the dialog by edit dialog action action in application designer and there you will get the clue. but high level its been because of improper migration or missing the relationship.
    Vivek Nagre
    JLL
