  • 1.  Global Directory set up for MAS 8
    Posted 08-02-2023 13:23
    I am trying to export data using publish channel in MAS 8 but publish channel giving me error when I google it I understand that there no global value present for mxe.int.globaldir system property.
    Could you please guide me how we can configure the global directory mxe.int.globaldir in MAS 8. Also, please let me know how we can check that location in open shift.
    Vaibhav Phalle
    JLL
  • 2.  RE: Global Directory set up for MAS 8
    Posted 08-03-2023 10:17
    Hi Vaibhav,
    This folder needs to be created inside the SMP folder structure (i think inside MEAWEB folder).
    Please check inside your folder structure if you have access.
    Subhransu Sekhar Sahoo
    PriceWaterHouseCoopers Services Pvt Ltd
  • 3.  RE: Global Directory set up for MAS 8
    Posted 08-03-2023 10:27
    For MAS 8 SMP folder is not there. its on open shift could you please guide me with steps how we can create folder on open shift if it is possible. I have open shift access.
    Vaibhav Phalle
    JLL
  • 4.  RE: Global Directory set up for MAS 8
    Posted 08-03-2023 11:30
    Hi Vaibhav,
    You need to have POD access to view and create folders inside SMP. Please check that.
