  • 1.  How to delete deprecated view from maximo
    Posted 06-22-2023 15:27
    We have a view that is not used yet. i want to delete this view because when i change the configuration of fields in the object that is extended by this view, the view is marked as changed and when i apply changes there is errors in the database configuration. i can't correct the sql of the view because it reference a dblink to a server that has been removed from our organization.
    so the question is: is it possible to delete a view from the database configuration application or by using sql requests ?
    Thank you for helping.
    Amar Msaid
    Societe des traversiers de Quebec (STQ)
  • 2.  RE: How to delete deprecated view from maximo
    Posted 06-23-2023 09:32
    Replace <VIEWNAME> with view that you want to delete and run below queries-
    DELETE FROM MAXOBJECT WHERE OBJECTNAME ='<VIEWNAME>'
    DELETE FROM MAXOBJECTCFG WHERE OBJECTNAME ='<VIEWNAME>'
    DELETE FROM MAXVIEW WHERE VIEWNAME ='<VIEWNAME>'
    DELETE FROM MAXVIEWCFG WHERE VIEWNAME ='<VIEWNAME>'
    DELETE FROM MAXATTRIBUTE WHERE OBJECTNAME ='<VIEWNAME>'
    DELETE FROM MAXATTRIBUTECFG WHERE OBJECTNAME ='<VIEWNAME>'
    Restart Maximo server after deletion.
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
