  • 1.  How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 07-13-2023 15:01
    Hi Everyone,
    We are trying to implement SAML SSO without LDAP. Just want to check how to manage the users without AD. The IDP will push the header information but is there any way maximo supports to read the header data and create User Records in Maximo also the security groups.
    I have got an answer stating custom cron has to be setup to pull the data from Identity provider.
    Is this a limitation of Maximo product that while making the SAML request Maximo can not read header data and create user during authentication between iDP and SP.
    If no how to create user if SMAL setup done without AD and LDAP.
    #Security
    #ServiceProvider
    Pradeep Rout
    TCSL
  • 2.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 07-17-2023 07:49
    Correct, there is no JIT provisioning of SAML users and we don't (yet) support the SCIM standard for automating the push of the user from your identity provider. This is on our roadmap (https://ibm-ai-apps.ideas.ibm.com/ideas/MSS1-I-27) but no specific release date and will only be valid for MAS (not the EAM 7.6.1.X product).
    Unfortunately, in the interim you need to build your own way of pushing in users. Most people integrate with the API of the Identity Provider such as the MS Graph API for Azure AD to handle in the interim.
  • 3.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 07-18-2023 11:09
    Hi Steven,
    Thanks for your reply. We will have LDAP for internal users for external we are using SAML configuration . SO basically there will be 2 authentication 1 is for internal with AD and LDAP another for external user with SAML. My question is even if we push the external users through Identity provider then what we suspect is as LDAP is there VMSYNC will run and remove these external users as these users are not AD users. Is there any way to filter and restrict the users not to be revoked when come through Identity provider. Please let us know if any additional filter can be set at VMSYNC level to manage this.
    Pradeep
    Pradeep Rout
    TCSL
  • 4.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 07-18-2023 11:34
    There are parameters on the VMMSYNC to filter but users that do not exist in LDAP should not be impacted from a user perspective. IE you can add a user that does not reside in LDAP and it should not deactivate the user because it wasn't found in LDAP. Now where you may be impacted is group synchronization. If you have a group that exists in LDAP and the user is not part of the group, they will be removed any time the synchronization occurs. Not all customers use this process to synchronize groups but if you do, you will need alternate security groups that do not exist in LDAP for users that are coming from SAML.
  • 5.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 07-18-2023 12:51
    Hi Steven,
    Thanks for your reply. What I understood you are referring to duplicate the security groups which are currently part of LDAP and rename it so that system will distinguish and  new groups will be linked to the external users .
    Thanks.
    Pradeep Rout
    TCSL
  • 6.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Best Answer
    Posted 07-18-2023 15:21
    I think we're on the same page but to be sure:
    If a security group (IE MAXADMIN) exists in LDAP and isn't filtered out by the group filter, then the VMMSYNC will add/remove users from the security group based on what exists in the domain. If user A is a non-LDAP user and you add them to MAXADMIN, they will be removed on the next synchronization.
    If a security group (IE SAMLMAXADMIN) does not exist in LDAP (or is filtered out), then any users in that group will need to be manually added/removed. This could include a SAML or LDAP user and neither will have the group removed on synchronization. You can duplicate/clone an existing security group to get it started but it's entirely managed by the customer.
  • 7.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 07-18-2023 16:45
    Thanks Steven.
    We will validate this and appreciate your help on this regard.
    Pradeep Rout
    TCSL
  • 8.  RE: How to Handel User Management through SAML without LDAP in Maximo 7.6
    Posted 08-14-2023 16:25
    Thanks steven for a quick help on user management query.
    Pradeep Rout
    TCSL
