  • 1.  How to return the response of the inbound Transaction using Script on Publish Channel
    Posted 05-02-2024 08:55
    Hi
    I have an requirement, Present we are using JSON Mapping  for Inbound Transaction. if there is no error then we need to send the JSON response back as " Transaction Success" or if there is a error then need to send the response as "Transaction Error"
    I have no idea how to achieve this. Could anyone please suggest me how to do this.
    Regards
    Sri
    SAI
  • 2.  RE: How to return the response of the inbound Transaction using Script on Publish Channel
    Posted 05-02-2024 12:52
    Based on your description on the requirement, you can implement customize response logic in Enterprise Service user exist java class, or through automation script.
    jacky qiu
    Amtrak
  • 3.  RE: How to return the response of the inbound Transaction using Script on Publish Channel
    Posted 05-02-2024 15:22
    Hi Jacky,
    I have tried but no luck. If you have any sample logic please let me know
    SAI
  • 4.  RE: How to return the response of the inbound Transaction using Script on Publish Channel
    Posted 05-02-2024 17:37
    Can you explain what you tried and paste your code here and what's the issue of your code? I might be able to help if I see the detail the information.
    jacky qiu
    Amtrak
