Is it possible to change status of OBSOLETE inventory item back to Active?
  • 1.  Is it possible to change status of OBSOLETE inventory item back to Active?
    Posted 02-13-2025 12:10
    Hello MORE Maximo community :)
    Is it possible to change the status of an OBSOLETE inventory item back to Active?  It was made OBSOLETE years ago, but is something that is being used currently.
  • 2.  RE: Is it possible to change status of OBSOLETE inventory item back to Active?
    Posted 02-13-2025 20:36
    Hi Danny
    When you change status to Obsolete Maximo clearly say it can't be brought back. So you can't do from UI.
    You can update status from backend though ITEM, INVENTORY and ITEMORGINFO table but it is not recommended as you may run into issues if all required table/columns are not updated.
    It is better to create item again.
    IBM Champion 2022|2023|2024|2025
    Lets learn MAS @ https://www.youtube.com/@reliabilityodyssey/
