Hi Keith,
That won't work as PM's don't repeat the the 1-2-3-4-1-6 pattern for a long while. What's being asked is really to have a repeating pattern, sequencing is not like that as Maximo always starts with the current counter + 1, then divideds each JP sequence start from the largest sequence value into that result i.e. 24/6 = 4 with a remainder of 0, so it uses that JP against the sequence of 6. Instead, if the counter is 27 + 1, then 28/6 = 4.67. As there is a 0.67 remainder, it's not sequence 6, so it moves onto the next largest sequence being 4, so (27+1)/6 = 7.00 which means it will use that JP.
So, this is why your idea does not work.
Maximo for Transportation does have something that could also work. It has PM relationships. One thing that PM relationships do it activate/deactivate a PM(s) when the current PM is generated.
So you can set this up.
PM1 (JP1000) Active initially, when this is generated it will activate PM2 and inactivate itself
PM2 (JP2000) Inactive initially, when this is generated it will activate PM3 and inactivate itself
PM3 (JP3000) Inactive initially, when this is generated it will activate PM1 and inactivate itself
This is great where there are different frequencies or you only want to do the initial PM say at 1,000 km (once only), then the next fires at 5,000 km (once only), then it's at 15,000 km thereafter. It would look like this:
PM1 (JP1000) Active, when this is generated it will activate PM2 and inactivate itself. Freq=1000 km
PM2 (JP6000) Inactive initially, when this is generated it will activate PM3 and inactivate itself. Freq=5000 km
PM3 (JP15000) Inactive initially, no other PM relationship is set. Freq=15,000 km
ISW
Maximo Practice Manager
eMail:
#IBMChampion2022
Sent: 07-25-2022 16:55
Subject: Is this PM sequence a candidate for Maximo Job Plan sequencing?
can you duplicate 1000HRT19 for 5000HRT19?
keith simmons
Aquitas Solutions
