Issue with loading inventory records using MXLoader
  • 1.  Issue with loading inventory records using MXLoader
    Posted 10-20-2022 07:25
    Client has requested us to enable the Application Export/Import option in the Inventory application and set the limit of both export and import to be 10k but we are getting a session timeout error when we try to set the limit to 10k.For 5 k,it is working fine but would like to ask if there could be a chance of any system bottleneck or any other issue if multiple users perform the export/import concurrently. We tried for 2 users concurrently and didn't observe any issue.
    Also, we tried to use the Loader to perform the export/import and we are getting an error for export of 5k records which is a strange behavior as Loader is designed to support large number of records. Is there any specific setting change to be done on the config sheet to support the export/import of bulk records in Inventory. We tried to use the batch process for export but it is not working and import is working as batch process for 10 k records only post which error is coming.
    Thank you for your help.
    Mahadevan.
    #HSE/OilandGas
    Mahadevan Ramakrishnan
