  • 1.  Main tab is read only ????
    Posted 06-05-2023 16:47
    Hello all,
    I built an application without "LIST" tab. Only I've the Main tab, but when the user comes to the application he founds all attributes  in screen are read only ???
    Can anyone explain why ? And how I can resolve it.
    Any help much appreciated.
    Thanks 🙏
    Mohammad Moula
    eSolution
  • 2.  RE: Main tab is read only ????
    Posted 06-05-2023 23:04
    Hi Have you put any restrictions on the main tab like the signature option
    or there is the possibility that you may select the main section on the main tab and made it read-only that will be the reason.
    3. check if you didn't apply any data restriction on that particular object
    Vivek Nagre
    JLL
  • 3.  RE: Main tab is read only ????
    Posted 06-07-2023 06:05
    Thanks for help , problem is resolved
