  • 1.  Maximo 7.6.1.3 and Transportation 7.6.2.6 Update Fail
    Posted 11-20-2023 11:32
    I performed the following Maximo updates using the IBM Installation Manager.
         Maximo 7.6.1.1 to Maximo 7.6.1.3 (file MAMMTFP7613IMRepo-signed.zip)
        Transportation 7.6.2.0 to 7.6.2.6 (file 7.6.2.6-TIV-TRN-FP0006.zip)
    I installed these two packages in the repository, and then with the Update utility, selected "Update all packages with recommended fixes and updates".
    The updates succeeded, and the ear build and install were successful.  Maximo started.  But there are issues.
    The 7.6.2.6 transportation class files are not in the ear (nor in the smp\maximo\... folders), but the database says these class files are installed.
    For example, class file psdi.plust.app.meter.PlusTFldDeployedMeterLastReading is part of the 7.6.2.6 (a new class, it's not in the 7.6.2.0 version), and it's registered to field assetmeter.lastreading.  But the class file is not in the ear.
    What to do?????
    Jose Nodeland
    JedaWorks
  • 2.  RE: Maximo 7.6.1.3 and Transportation 7.6.2.6 Update Fail
    Posted 11-20-2023 15:26
    I removed 7.6.2.6-TIV-TRN-FP0006.zip from installation manager, restarted installation manager, and added 7.6.2.6-TIV-TRN-FP0006.zip back as a repository.  Then did the Update procedure, and the class files were installed in the ear.
    Don't know why it did not work the first time, but all good now.
    Jose Nodeland
    JedaWorks
