  • 1.  Maximo DB migration from MS SQL to IBM DB2
    Posted 08-31-2022 07:55
    we are in the process of consolidating two IBM Maximo installation into one.
    Let say Maximo1 is on MS SQL DB, Maximo2 is on IBM DB2. Target is to create new Maximo infrastructure that will use IBM DB2 on Linux, and to transfer/migrate data from Maximo 1 and Maximo 2 to new infrastructure. I found on Redbook - "Microsoft SQL Server to IBM DB2 UDB Conversion Guide" where some aspects are discussed, but it is quite old. I was wondering if someone is performed such migration and if possible to share experience and guidelines.
    Thank you in advance!
    Chavdar
    #Infrastructure
    Chavdar Cholev
    Home
  • 2.  RE: Maximo DB migration from MS SQL to IBM DB2
    Posted 08-31-2022 09:00
    Are you planning to merge your two Maximo systems into a single database? If so, that's honestly more significant than the database conversion aspect. There are many tables in Maximo that are at a system level, such as reports, screens, person & user records, SRs, etc. And there are some that can be at a system level like job plans. If you try to merge them into the same organization that list grows significantly (item, labor, companies, contracts, masterpm, etc.). This requires a lot of analysis of conflicts and the appropriate way to address. For example, if you have a conflict on person you have to determine if these two people are the same (and thus you need to merge the data from the systems) or do they represent different people and you need to now remap all references to this person across all tables in the system as part of your load.
    There are also a variety of settings at a system level such as system properties, certain MAXVAR settings such as whether job plans utilize revision or not, etc. These would have to be analyzed and decided upon if they have different configurations.
    If you're utilizing the same infrastructure but keeping them as two separate databases then your potential issues goes significantly down. And because you're going from SQL Server (which is typically configured as case insensitive for Maximo deployments) to DB2 (which is case sensitive), you're less likely to hit issue than the reverse. Some customers take advantage of the case sensitive aspect of DB2 and have had multiple values (such as two otherwise identical email addresses with different cases) that would be an issue loading into a case insensitive database.
    As for how you get the DB2 database, some customers prefer going through a MAXINST (creating a blank database with the out of the box schema) and migrating all their changes from the original system. This is what we would typically call a reimplementation because it gives customers an opportunity to fix things they didn't like in their old system. Some actually try to go through the conversion of their database and address issues that occur with that process. Either approach you will still need to review and modify the Maximo configuration, such as saved queries, relationships, KPIs, reports, system properties (such as mxe.db.systemdateformat where we track which function to call on that database platform), etc.
    There are people who have done this but you're not going to find any public documentation on it really. Database conversions, merges, etc. typically are done as professional services engagements so it's not something people can share unfortunately. Unless you're really knowledgeable on both Maximo and the underlying database platforms, I would consider engaging outside resources on something like this. There are some business partners who do this routinely and have tooling to make these transitions smoother.
  • 3.  RE: Maximo DB migration from MS SQL to IBM DB2
    Posted 08-31-2022 10:24
    As always, Thank you Steven !!!
    Our intention is to use multitenancy. On Maximo infrastructure that is on MS SQL DB we do have two organization with single site in each org.
    May be it would be good idea to use DB2, but let say data from MS SQL to me be migrated to DB2 server on let say MaximoDB1 Db, while Maximo infra that is currently using DB to stay as it is?
    Thank you
    Chavdar Cholev
    Home
  • 4.  RE: Maximo DB migration from MS SQL to IBM DB2
    Posted 08-31-2022 09:25
    Hello Chavdar,
    Some documentation is available but it has to be validated in context of Maximo for sure.
    https://www.ibm.com/docs/en/sim/6.0.0.22?topic=usim-migrating-from-microsoft-sqlserver-db2-when-upgrading-from-tivoli-identity-manager-version-5
    Prashant
    Sedin Technologies
    #IBM Champion 2022
  • 5.  RE: Maximo DB migration from MS SQL to IBM DB2
    Posted 08-31-2022 10:25
    Thank you Prashant !!!
    I went through the documentation and it gave me some very useful points to think about !
    Chavdar Cholev
    Home
