  • 1.  Maximo Mobile Technician – todaywoassignedDS / MXAPIWODETAIL 504 Gateway Timeout (DB2 SQLCODE=-952)
    Posted 15 days ago
    Edited by RAJIBA GOUDA 14 days ago
    Hi Everyone,
    I'm troubleshooting an issue in Maximo Application Suite (Manage + Mobile Technician) and wanted to see if anyone has encountered something similar.
    Environment
    • MAS Manage / Mobile Technician
    • DB2 backend
    • Mobile Technician application
    • User login succeeds
    • Mobile application loads
    • Assigned Work Orders fail to load
    Mobile logs show:
    We're also seeing occasional timeouts against:
    MXAPITKCLASS
    savedQuery=MOBILECLASSSTRUCTURE
    which makes me wonder if this is:
    Missing DB2 indexes
    Poor query plan
    Large WFASSIGNMENT table
    Large PERSONGROUPTEAM table
    MXAPIWODETAIL customization
    Infrastructure timeout (Ingress/ALB)
    General database performance issue
    Questions :
    1. Has anyone seen SQLCODE=-952 / SQLSTATE=57014 during MXAPIWODETAIL processing?
    2. Was the root cause database indexing, object structure configuration, or infrastructure timeout?
    3. Did anyone identify specific indexes on:
      • WFASSIGNMENT
      • PERSONGROUPTEAM
      • WORKORDER that resolved similar Mobile timeout issues?
    4. Were there any custom relationships or child objects in MXAPIWODETAIL that caused excessive response time?
    5. How did you ultimately resolve the 504 Gateway Timeout?
    Any guidance, execution plan examples, or lessons learned would be greatly appreciated.
    Thanks!
    RAJIBA GOUDA
  • 2.  RE: Maximo Mobile Technician – todaywoassignedDS / MXAPIWODETAIL 504 Gateway Timeout (DB2 SQLCODE=-952)
    Posted 15 days ago
    Hi Rajiba,
    It is highly likely that the root cause of your issue is linked to: "504 Gateway Time-out. Even a direct call to: https://<server>/oslc/os/mxapiwodetail?lean=1 "
    Replace the /oslc route with /api and use an API Key in the header. Example:
    GET https://mydomain/maximo/api/os/mxapiasset?lean=1&oslc.pageSize=10&oslc.select=assetnum,siteid,description
    apikey: xxxxxxxxxx
    The issue is related to MAS Integration
    Fredrick Ndwaru
    Perpetual Ignition
  • 3.  RE: Maximo Mobile Technician – todaywoassignedDS / MXAPIWODETAIL 504 Gateway Timeout (DB2 SQLCODE=-952)
    Posted 12 days ago
    Thanks @FREDRICK NDWARU, attached more logs. Could you please check
    RAJIBA GOUDA
  • 4.  RE: Maximo Mobile Technician – todaywoassignedDS / MXAPIWODETAIL 504 Gateway Timeout (DB2 SQLCODE=-952)
    Posted 12 days ago
    @RAJIBA GOUDA, can you test the Maximo Mobile APIs in https://www.ibm.com/docs/en/masv-and-l/maximo-manage/cd?topic=reference-maximo-mobile-rest-apis
    1. First, test https://<server>/maximo/oslc/whoami from your UI after logging into Maximo. The expectation is an instant JSON response with your user details.
    2. Then test https://<server>/oslc/os/mxapiwodetail?lean=1&oslc.pageSize=10 from your UI. The expectation is a JSON response with the first ten WOs. Scroll to the bottom of the JSON response to view the page total, which should also include the total pages.
    3. Finally, test  https://<server>/oslc/os/mxapiwodetail?lean=1; the expectation is a replication of the error or a response of all pages totaling the total pages
    4. To trigger and download a heap dump for a specific server instance or pod in Maximo Application Suite (MAS) 9.2 Manage, use the Maximo Management Interface (MMI) REST API endpoint: http://<host>:<port>/maximo/oslc/members/<memberid>/heapdump (or /maximo/api/members/<memberid>/heapdump).
    5. Here is the MAS 9.2 link for additional Performance tips
      1. I've added the ignorecollectionref=1 query parameter to remove the collection ref to child collections from the response JSON to optimize further (2).   https://<server>/maximo/api/os/mxapiwodetail?lean=1&oslc.pageSize=10&ignorecollectionref=1
    Fredrick Ndwaru
    Perpetual Ignition
