Maximo Report error intermittent on scheduled report -
This issue started after upgrading servers from 2012R2 to 2019 for the Application and Integration servers.
Reports are set to run on the integration server.
Reports run fine one day, next day three reports error, or two reports error, is its endless cycle.
Deleted the reports schedule, rescheduled reports.
Regenerated all of the reports.
Servers have been restarted.
URLS match reportsched table
nothing in the reportjob or reportrun queue.
Suggestions or Ideas, this is happening on all scheduled reports, you can manually run the report successfully.
ERROR
[INVENTOR] com_inventory_balance_tbl.rptdesign
psdi.util.MXApplicationException: BMXAA5480E - The report com_inventory_balance_tbl.rptdesign of the INVENTOR application failed to run.
BMXAA5476E - The report com_inventory_balance_tbl.rptdesign could not be prepared to run.
BIRT Report Engine not initialized properly for this operation to work.
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.runReport(ReportAdminService.java:3741)
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.runReport(ReportAdminService.java:3659)
at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager.runQueuedReport(ReportQueueManager.java:960)
at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager.runQueuedReport(ReportQueueManager.java:859)
at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager.doWork(ReportQueueManager.java:660)
at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager$ReportRunThread.attemptToRunReport(ReportQueueManager.java:515)
at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager$ReportRunThread.run(ReportQueueManager.java:454)
Caused by: psdi.util.MXApplicationException: BMXAA5476E - The report com_inventory_balance_tbl.rptdesign could not be prepared to run.
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.prepareReportDesignForRun(ReportAdminService.java:2537)
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.prepareReportDesignForRun(ReportAdminService.java:2461)
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.prepareReportForRun(ReportAdminService.java:2211)
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.runReport(ReportAdminService.java:3701)
... 6 more
Caused by: java.lang.IllegalStateException: BIRT Report Engine not initialized properly for this operation to work.
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.updateRuntimeReportDesign(ReportAdminService.java:5451)
at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.prepareReportDesignForRun(ReportAdminService.java:2514)
... 9 more
#Reporting------------------------------
Diane Nohner
City of Minneapolis
