  • 1.  Maximo Script - WORKORDER.NEW
    Posted 10-19-2023 10:21
    Hello!
    I'm trying to setup some default data on a new work order for a specific site but when I run the following script nothing happens, I don't get any error from Maximo and the fields are not populated with the default values. Any suggestions?
    workorder = mbo.getOwner()
    if workorder and workorder.isBasedOn("WORKORDER"):
        if app == 'WOTRACK':
            if mbo.getString("siteid") == 'BEDFORD':
                mbo.setValue("STATUS", "INPRG", MboConstants.NOACCESSCHECK)
                mbo.setValue("GLACCOUNT", "50020.200.5210")
    Julio Roca
    BCBS
  • 2.  RE: Maximo Script - WORKORDER.NEW
    Best Answer
    Posted 10-19-2023 13:23
    When you're creating a work order, you normally will not have an owner. Think of the owner in the context of something like PR->PRLINE. If you had a script on PRLINE.NEW, then the PRLINE owner would be the PR header. You may be creating a WO specially where it does have a parent, but the second line there "workorder = mbo.getOwner()" is likely going to be null. You normally would just be using mbo. IE:
    if mbo and mbo.isBasedOn("WORKORDER"):
  • 3.  RE: Maximo Script - WORKORDER.NEW
    Posted 10-20-2023 04:04
    Hello Steven,
    Your explanation is right on target and now this works like a charm!
    Thank you so much for your help!
    JR
    Julio Roca
    BCBS
  • 4.  RE: Maximo Script - WORKORDER.NEW
    Posted 12-31-2023 00:09
    Hey @Julio Roca i have tried the script and it works fine.
    if mboname=='WORKORDER' and app=='WOTRACK' and mbo.getString('SITEID')=='BEDFORD':
        mbo.setValue('DESCRIPTION','script triggered WOTRACK.new')
        mbo.changeStatus("INPRG", MXServer.getMXServer().getDate(), "Status Changed from .NEW Script")
        mbo.setValue('GLACCOUNT','6000-200-000')
        wostatus=mbo.getMboSet('WOSTATUS')
    Vivek Nagre
    JLL
Featured Podcast
Watch the Podcast
Watch the latest episode
