Maximo Start Center portlet for application PM - ERLSTWOGENDATE missing from field configuration>object list
  • 1.  Maximo Start Center portlet for application PM - ERLSTWOGENDATE missing from field configuration>object list
    Posted 02-04-2026 15:19
    Edited by Diane Nohner 02-04-2026 15:23
    using Maximo 7.6.1.3 Asset Management
    Trying to add the PM.ERLSTWOGENDATE to a start center portlet
    In the results set up – field configuration>object list
    The field is not present - ERLSTWOGENDATE
    Is there a way to add the filed to the results set for PM's to add to the portlet?
    *note that in the portlet there are 105 fields and in the database there are 128.
    In the PM table the filed is present – is this due to this being a calculated field? – see explanation below
    Earliest Next Due Date Calculation Explained
    Question & Answer
    Question
    What is the formula used to calculate the Earliest Next Due Date (PM.ERLSTWOGENDATE) for PMs?
    Answer
    The formula for the Earliest Next Due Date is:
    If the Target Start = Y then it is PM.LASTSTARTDATE + PM.FREQUENCY
    else (Target Start = N) it is PM.LASTCOMPDATE + PM.FREQUENCY
    For Meter based PMs:
    Units to go = Life to Date next meter reading (not shown in the UI,PMMETER.LTDREADATNEXTWO) - life to date current meter reading (ASSETMETER.LIFETODATE) - Generate wo ahead by (PMMETER.TOLERANCE)
    Estimated Next Due Date = Todays date +( Units to go/ASSETMETER.AVERAGE) The estimated due date in PM tab is the earliest of date based and meter based dates.
    #WorkCenters
    Diane Nohner
    City of Minneapolis
  • 2.  RE: Maximo Start Center portlet for application PM - ERLSTWOGENDATE missing from field configuration>object list
    Posted 02-05-2026 09:22
    Edited by Steven Shull 02-05-2026 09:22
    You are unfortunately correct. Because this is non-persistent there's not a supported way to get it to be returned.
    The new Operational Dashboard in MAS uses the REST API and will support returning non-persistent attributes if they're included on the object structure.
Watch Episode 6
