  • 1.  Maximo Support Technical Exchange recordings
    Posted 06-04-2025 00:59
    Does anyone know if the old Maximo Support Technical Exchange records (Tivoli) are available somewhere?  Those are some of the most valuable documents I've ever seen on Maximo.
    They're dated around the time that Maximo 7.5 was released, i.e. about 2012 or so.
    Thanks in advance
    Shannon Rotz
    InComm Solutions Inc.
  • 2.  RE: Maximo Support Technical Exchange recordings
    Posted 06-04-2025 11:29
    I'm not familiar with the particular recordings but most of the content around that time was hosted in developerworks and that platform was sunset many years ago. Unfortunately, a lot of content was lost when that happened. I doubt anyone outside of IBM has them available and I'm not sure even anyone inside IBM has it at this point.
    @Steven Hauptman sorry for tagging you directly but you're the only one I can think of that might be aware of this and know if the material still exists somewhere.
  • 3.  RE: Maximo Support Technical Exchange recordings
    Posted 06-04-2025 19:16
    Steven, no worries.
    I am asking around to see if anyone knows the whereabouts.
    Shannon, were these recordings or just records like PPT, PDF, etc?
    Steven Hauptman
  • 4.  RE: Maximo Support Technical Exchange recordings
    Posted 06-04-2025 19:53
    They were recordings.
    The logo on the records is SABA, if that helps.
    Note:  I have two of them - they are presentations by Kevin Buonagario before he left (I can forward them back to you if they're lost).
    I'm looking for the one by a developer named David (can't remember the last name) in which he gave the details of the new work order functionality that was added to 7.5.
  • 5.  RE: Maximo Support Technical Exchange recordings
    Posted 06-20-2025 10:21
    Hi Shannon, I did some searching around (and had some others do as well) but those recordings seem to be gone.  Is there anything specific you were looking for?
    Steven Hauptman
  • 6.  RE: Maximo Support Technical Exchange recordings
    Posted 06-20-2025 10:33
    I'm trying to remember the exact calculations that Maximo uses for the status change to WMATL at this point. If you could help there, I'd appreciate it.
    In the meantime, I'll keep digging around - I really thought I had a copy.
    The developer's name was David Hallican, I think.
  • 7.  RE: Maximo Support Technical Exchange recordings
    Posted 06-22-2025 14:14
    David Havican was an architect around that time so definitely believable that he had done a recording.
    This is the best document on WMATL I am aware of but there are likely others: Material Availability Status on Work Orders
  • 8.  RE: Maximo Support Technical Exchange recordings
    Posted 06-24-2025 09:44
    Thanks Steven - I'll go look these up.  Much appreciated!
    Shannon Rotz
  • 9.  RE: Maximo Support Technical Exchange recordings
    Posted 06-24-2025 09:08
    Shannon,
    Send me a contact email - I believe I have what your looking for on an old (whopping at the time 100GB portable hard drive) It was the SABA reference that tweaked my memory...
    Ken..
    Ken Thomson
    Aquitas Solutions
  • 10.  RE: Maximo Support Technical Exchange recordings
    Posted 06-24-2025 09:43
    Wonderful!  I've sent you a private mail via this site.
