  • 1.  Run MASUSERSYNC cron in Manage (Syncronize Manage users to MAS)
    Posted 02-19-2024 06:44
    WE have SAS FLex environment migrating from 7.6.1.2 to 8.11 , there is a requirement to config and  Run MASUSERSYNC , Please let me know if anyone has performed this action in any of the upgrade project
    uttam ibbandi
    ibm
  • 2.  RE: Run MASUSERSYNC cron in Manage (Syncronize Manage users to MAS)
    Posted 02-19-2024 10:28
    Uttam
    When doing the upgrade it should run once to sync all of your 7.6. users up to MAS. This has worked on the few environments that I have utilized this for. I have also used this a few times to sync users by manually activating it once on MAS to sync in additional users. This can be helpful if you do something like a production to development database refresh for the first time and you need to load users into MAS from the Manage DB.
    Phil Runion
    Projetech
  • 3.  RE: Run MASUSERSYNC cron in Manage (Syncronize Manage users to MAS)
    Posted 02-20-2024 11:21
    Uttam,
    For me the MASUSERSync program automatically ran during the upgrade process.  When you Activate Manage and it is pointed to a database which has not been upgraded it automatically runs updateDB and runs through various upgrade scripts/processes.
    The MASUSERSync crontask bombed on bad data so I ran into the scenario where all users weren't syncing.  I had to trace the program, fix the bad data, then rerun the crontask to get everything synced.  There is a field MASUSER.MASISSUER.  If that field is null then you know that user was not synced by the MASUSERSync crontask.
    Eric Burkland
    San Diego County Water Authority
