Hi Craig: I haven't contacted IBM, no, although I agree that would be a good thing. We just identified this issue, first, and second, since we're on 7.6.0.9 I don't know if I have access to that portion of Support anymore (too bad - 98% of the time I can handle the issues that come up, but I sure would like IBM input on this particular one :( ). We don't use SNTL or FNLT, so those are non-issues, but AFAIK Target Finish is still being set to Target Start Date plus Duration (although I might have to re-check that at some point too.)
Gail: SNTL (SNEL??) = "Start No Earlier Than", FNLT = "Finish No Later Than"
Shannon Rotz
InComm Solutions Inc.
Sent: 02-29-2024 17:54
Subject: Setting the Lead Time on Meter-Based PM Work Orders
Hi Gail and Shannon,
This is yet another one of those things with Maximo that without observation, I never saw happening. May I ask if this behaviour has been out through to IBM as an bug or have you raised an IBM Idea? The issue you've raised is a bit of a fundamental thing for IBM to get right.
Further as part of the fix for the target start date, do you also look at reframing the SNTL, FNLT, and target finish dates as all of these are centric on the target start date?
Principal Consultant
COSOL
#IBMChampion
Sent: 02-27-2024 11:05
Yep, we had it like this for years. It was annoying, and we just excluded MPMs from overdue metrics. However, last year we wrote a script to run on WO generation's Save that if WORKTYPE=MPM, to recalculate the Target Start Date something along the lines of: (PMMETER.TOLERANCE / PMMETER.AVERAGE) + GETDATE(). So now WOs can generate early enough for material planning, and there's a relatively accurate Target Start Date.
gail smith
chevron
