  • 1.  SQL in Automations script
    Posted 07-11-2023 04:40
    Edited by Mohammad Moula 07-11-2023 06:21
    Hello all,
    Following is a script that I developed to fetch the a certain records using SQL and then I want to read record by record to the end of result set "RS". I have a problem that I do not get any error but there is no impact of the process as the script does not do any modification.
    NOTE: When I use " while rs is not None:"  instead of ""while (rs.next())" then
     it seems it is get into the loop but then I've an error at "mTSDAY = str(rs.getDate(TS_DAY))"
    Any hep much appreciated.
    from java.util.concurrent import TimeUnit
    from java.lang import Math
    from java.text import SimpleDateFormat
    from psdi.security import ConnectionKey
    from java.sql import Connection
    from java.sql import Statement
    mTS = MXServer.getMXServer().getMboSet("ZZAMSTIMECARD", mbo.getUserInfo())
    mBIO = MXServer.getMXServer().getMboSet("ZZICLOCK", mbo.getUserInfo())
    connKey = mbo.getThisMboSet().getUserInfo().getConnectionKey()
    conn = mbo.getThisMboSet().getMboServer().getDBConnection(connKey)
    sql = "SELECT DISTINCT FINGERNO, TS_DAY, TS_YEAR, TS_MONTH, PUNCH_IN, PUNCH_OUT, TSDAY_CHAR FROM (SELECT A.EMP_CODE FINGERNO, TRUNC(A.PUNCH_TIME) TS_DAY, EXTRACT(YEAR FROM PUNCH_TIME) TS_YEAR, EXTRACT(MONTH FROM PUNCH_TIME) TS_MONTH, SUBSTR(TO_CHAR ((SELECT MIN(PUNCH_TIME) FROM ZZICLOCK B WHERE A.EMP_CODE=B.EMP_CODE AND TRUNC(A.PUNCH_TIME)=TRUNC(B.PUNCH_TIME)),'DD/MM/YYYY HH24:MI:SS'),12,5) PUNCH_IN, SUBSTR(TO_CHAR ((SELECT MAX(PUNCH_TIME) FROM ZZICLOCK B WHERE A.EMP_CODE=B.EMP_CODE AND TRUNC(A.PUNCH_TIME)=TRUNC(B.PUNCH_TIME)),'DD/MM/YYYY HH24:MI:SS'),12,5) PUNCH_OUT,SUBSTR(TO_CHAR ((SELECT MAX(PUNCH_TIME) FROM ZZICLOCK B WHERE A.EMP_CODE=B.EMP_CODE AND TRUNC(A.PUNCH_TIME)=TRUNC(B.PUNCH_TIME)),'DD/MM/YYYY HH24:MI:SS'),1,10) TSDAY_CHAR FROM ZZICLOCK A where trunc(a.punch_time)>=(select max(TRUNC(ts_day)) from zzamstimecard)) order by FINGERNO, ts_day"
    s = conn.createStatement()
    rs = s.executeQuery(sql)
    conn.commit()
    while (rs.next()):
        mTSDAY = str(rs.getDate("TS_DAY"))
        #mTS.setWhere("TS_DAY=:rs.ts_day and FINGERNO=:rs.fingerno")
        mTSS = mTS.getMboSet("$NewWO","ZZAMSTIMECARD","FINGERNO='" + rs.getString("FINGERNO") + "'");
        if mTS.isEmpty():
            mTIMESHEET = mTS.add()
            mTIMESHEET.setValue("TS_DAY",rs.getDate("TS_DAY"))
            mTIMESHEET.setValue("FINGERNO",rs.getString("FINGERNO"))
            mTIMESHEET.setValue("PUNCH_IN",rs.getString("PUNCH_IN"))
            mTIMESHEET.setValue("PUNCH_OUT",rs.getString("PUNCH_OUT"))
        else:
            mTS.setValue("PUNCH_IN",rs.getString("PUNCH_IN"))
            mTS.setValue("PUNCH_OUT",rs.getString("PUNCH_OUT"))
        mTIMESHEET = mTS.save()
    Mohammad Moula
    eSolution
