  • 1.  Strange behavior in MAS Manage application designer
    Posted 10-02-2024 10:34
    Edited by Jade Warren 10-11-2024 12:10
    Has anyone else noticed some strange behavior in the Application Designer screen in MAS?  Specifically, when you click on various elements, the overall vertical spacing increases, and each time you click the vertical spacing continues to increase?
    Also, far more rarely, when you click one element it "jumps" to the top of a section...
    Or am I the only one?
    @Steven Shull any ideas?
    Jade Warren
    Great River Energy
  • 2.  RE: Strange behavior in MAS Manage application designer
    Posted 10-03-2024 17:13
    I've seen it many times in 7.6.1.x too. The column expanding issue doesn't cause a problem, you can continue to edit and save the change. But for the element jumping issue, I had to reset the change, otherwise, it will break the layout.
    I also saw another new issue with MAS 8.11, when creating a new single app, when adding a new column to the table header, everything disappeared. I had to edit the app in XML.
    Viet Tran
    https://relia.app
  • 3.  RE: Strange behavior in MAS Manage application designer
    Posted 12-20-2024 10:55
    MAS 9.0.2 and I have experienced the same thing as Viet, single page application add a column to a table and the entire 'preview' disappears.  Very annoying.
    Ken Thomson
    Aquitas Solutions
