#TipTuesday: Why Maximo Says "Record Has Been Updated by Another User"
  • 1.  #TipTuesday: Why Maximo Says "Record Has Been Updated by Another User"
    Posted 04-07-2026 11:37
    Edited by Lucas Pletz 04-07-2026 11:38
    Hi Maximo Open Forum,
    Have you ever tried to save a record and received a message like this?
    Maximo is preventing you saving because the record has changed after you opened it.
    What is happening:
    You open a record and begin making changes
    While you are working, the same record gets updated
    When you try to save, Maximo blocks the change to avoid overwriting data
    Common causes:
    Another user editing the same record
    Automation scripts or escalations updating the record
    A status change happening in the background
    In most cases, nothing looks different on the users screen, but the record was still updated.
    Maximo keeps track of each update using a value called a rowstamp. If that value changes before you save, the update is rejected to prevent overwriting data.
    IBM explains this behavior here:
    https://www.ibm.com/support/pages/record-has-been-updated-another-user?view=full
    What you can do:
    Refresh the record
    Re-enter the info you were using
    Save again
    My tip here is, every few fields you adjust or every minute or so, save the record so you do not lose your progress by someone else making a change :)
    Happy #TipTuesday
    Lucas Pletz
