TLS/SSL Certificate Management with MAS/Manage
  • 1.  TLS/SSL Certificate Management with MAS/Manage
    Posted 01-17-2024 19:15
    Good Afternoon,
    Does anyone have any good step-by-step instructions for how to manage TLS/SSL Certificates in Maximo Application Suite/Manage.  In Maximo Asset Management 7.6.1 it's pretty straight forward with IBM Key Manager.  App Suite it's all done within OpenShift and IBM's documentation is confusing.
    We currently use a wildcard cert *.domain.com  signed by goDaddy.  I assume that a wildcard cert such as the one we have covers all subdomains
    Here is an example of a  MAS Admin Dashboard URL https://auth.masdmo.apps.oc.domain.com/
    I've followed Manual certificate management
    Ibm remove preview
    When you configure the suite, you can enable manual certificate management to upload your public transport layer security (TLS) certificates in Maximo Application Suite. After you enable certificate management, you can add certificates by adding secrets to your cluster in Red Hat OpenShift or by uploading certificates for your instance in the Maximo Application Suite user interface.
    View this on Ibm >
    To see if I could manually add the certificates and it looks like it added them but it is still saying the connection isn't secure.  I'm wondering if my issue is the server doesn't recognize goDaddy as a trusted CA.
    Any information would be appreciated.
    Eric Burkland
    San Diego County Water Authority
  • 2.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 01-23-2024 13:44
    So figured out the problem with the help of IBM and goDaddy.  Issue is our standard wildcard certificate which we have used for many years won't work with Maximo Application Suite.  This is because Maximo application suite and other products (i.e. Manage) have URLs which are 4/5/6 level subdomains deep.  We ended up purchasing a certificate which allows for Subject Alternative Names (SAN).
    BTW each instance of maximo requires 5 SANs if you are using just core and Manage.  If you install other products it is likely even more.
    Cheers!
    Eric
    Eric Burkland
  • 3.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 01-24-2024 09:35
    We had the same issue a couple years ago when first insall MAS,  I had suggested/requested IBM MAS to use '-' instead '.' to construct their URLs like everyone else does. It (dot in URL) really created unnecessary complexity in certs, network load balancer config etc.
    Jiang Monge
    GM
  • 4.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 07-15-2024 23:59
    Hey - was just going down this road and only came up with 3 SANs when looking at Core and Manage in https://www.ibm.com/docs/en/mas-cd/continuous-delivery?topic=management-manual-certificate
    *.masdomain
    *.manage.masdomain
    *.home.masdomain
    I was wondering what the other 2 were you used. Did you use a multi-domain wildcard cert?
    Andy
    Andrew Meuse
    JFC & Associates
  • 5.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 07-17-2024 11:34
    Andrew,
    Here are the SANs we have:
    *.apps.<OCCLUSTER>
    *.home.<MASDOMAIN>.apps.<OCCLUSTER>
    *.manage.<MASDOMAIN>.apps.<OCCLUSTER>
    *.<MASDOMAIN>.apps.<OCCLUSTER>
    Whether or not this is correct I can't be sure but we've had no issues.
    BTW if you have other products other than manage you'd need additional SANs
    For Example
    *.predict.<MASDOMAIN>.apps.<OCCLUSTER>
    Eric
    Eric Burkland
  • 6.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 12-20-2025 22:11
    Hi Eric,
    I am in a similar situation, currently implementing MAS with manually managed certificates. Based on your experience, did you proceed with a single multi-domain (SAN) certificate that includes all required SAN entries, or did you purchase separate certificates for each SAN? Additionally, which DNS and SSL provider did you use?
    Best regards,
    Jean
    JEAN EROLD Jiraud
    Beyosatech
  • 7.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 01-05-2026 12:45
    Hi Jean,
    Sorry for the late response.  We had to request a special product from goDaddy:
    Standard DV UCC/SAN/Wildcard SSL Up to 20 Domains Multiple Domain UCC/SAN/Wildcard SSL
    So this is one certificate or as you put it a single multi-domain (SAN) certificate that includes all required SAN entries.
    Hope this helps,
    Eric
    Eric Burkland
  • 8.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 03-31-2026 17:00
    Out of curiosity, has anyone gotten it working with Maximo Mobile properly? We did the Wildcard SSL with 10 SANs on it that should cover all the URLs we need, but our stuff is also behind Cloudflare and they have Lets Encrypt certificates on the external endpoints. We cannot get Maximo Mobile to connect from outside the network no matter what we've tried so far.
    Dominic Russo
    TechAdept Solutions LLC
  • 9.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 04-01-2026 14:22
    This sounds odd. It should work. Are you using home.* URL (the one from Core namespace) for your mobile devices?
    Arif Ali
  • 10.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 04-01-2026 16:51
    Well of course, the next day after I posted, it all got worked out! Apparently there was an extra firewall in-between that also needed the cert!
    Dominic Russo
  • 11.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 04-23-2026 09:21
    I'm in a similar situation. Our app is secured behind the firewall using the required SANs, and we're working on exposing the correct A records to enable mobile connectivity. IBM support has been giving us inconsistent answers.
    We currently have one A record for main.home.<mas-url>, but when attempting to log in via mobile, the logs are also looking for api.<mas-url>.
    We've submitted an A record for latter and are awaiting validation, but I wanted to ask, what specific URLs did you expose to get mobile connectivity working?
    Brett Coleman
    Georgia Building Authority
  • 12.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 04-23-2026 09:30
    Tinnokesh AP linked a good article (that I had never come across before so thanks!) that has them all listed out, but I looked at the certs on one of our customer's IBM SaaS hosted environments and saw the full list of SANs they auto-generated for their certs so I'm providing it below:
    DNS Name=admin.[yourBaseURL].com
    DNS Name=admin.monitor.[yourBaseURL].com
    DNS Name=api.[yourBaseURL].com
    DNS Name=api.monitor.[yourBaseURL].com
    DNS Name=api.optimizer.[yourBaseURL].com
    DNS Name=arcgis.[yourBaseURL].com
    DNS Name=assist.[yourBaseURL].com
    DNS Name=auth.[yourBaseURL].com
    DNS Name=edgeconfig.iot.[yourBaseURL].com
    DNS Name=edgeconfigapi.iot.[yourBaseURL].com
    DNS Name=health.[yourBaseURL].com
    DNS Name=home.[yourBaseURL].com
    DNS Name=iot.[yourBaseURL].com
    DNS Name=[yourBaseURL].com
    DNS Name=main-all.health.[yourBaseURL].com
    DNS Name=main-all.manage.[yourBaseURL].com
    DNS Name=main-cron.health.[yourBaseURL].com
    DNS Name=main-cron.manage.[yourBaseURL].com
    DNS Name=main-jms.health.[yourBaseURL].com
    DNS Name=main-jms.manage.[yourBaseURL].com
    DNS Name=main-mea.health.[yourBaseURL].com
    DNS Name=main-mea.manage.[yourBaseURL].com
    DNS Name=main-rpt.health.[yourBaseURL].com
    DNS Name=main-rpt.manage.[yourBaseURL].com
    DNS Name=main-ui.health.[yourBaseURL].com
    DNS Name=main-ui.manage.[yourBaseURL].com
    DNS Name=main.api.monitor.[yourBaseURL].com
    DNS Name=main.api.optimizer.[yourBaseURL].com
    DNS Name=main.argis.[yourBaseURL].com
    DNS Name=main.assist.[yourBaseURL].com
    DNS Name=main.edgeconfig.iot.[yourBaseURL].com
    DNS Name=main.edgeconfigapi.iot.[yourBaseURL].com
    DNS Name=main.health.[yourBaseURL].com
    DNS Name=main.home.[yourBaseURL].com
    DNS Name=main.iot.[yourBaseURL].com
    DNS Name=main.manage.[yourBaseURL].com
    DNS Name=main.messaging.iot.[yourBaseURL].com
    DNS Name=main.monitor.[yourBaseURL].com
    DNS Name=main.optimizer.[yourBaseURL].com
    DNS Name=main.predict.[yourBaseURL].com
    DNS Name=main.visualinspection.[yourBaseURL].com
    DNS Name=manage.[yourBaseURL].com
    DNS Name=maxinst.health.[yourBaseURL].com
    DNS Name=maxinst.manage.[yourBaseURL].com
    DNS Name=messaging.iot.[yourBaseURL].com
    DNS Name=monitor.[yourBaseURL].com
    DNS Name=optimizer.[yourBaseURL].com
    DNS Name=predict.[yourBaseURL].com
    DNS Name=sls.[yourBaseURL].com
    DNS Name=visualinspection.[yourBaseURL].com
    Dominic Russo
  • 13.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 04-23-2026 14:07
    Thanks Dominic. We used that documentation to do our request from our CA, but it looks like we are just going to have to expose way more routes than we were planning on.
    Makes me wonder if it would just be easier to submit the wildcard SANs as A records instead of having them create 10+ records for the individual routes.
    Brett Coleman
  • 14.  RE: TLS/SSL Certificate Management with MAS/Manage
    Posted 04-05-2026 05:11
    Hello Jean,
    You can use single certificate with all the possible SAN included. Please refer to the below blog for the possible SANs you may need to build for certificate creation.
    https://www.ibm.com/docs/en/masv-and-l/cd?topic=management-certificate-configuration
    Tinnokesh AP
