Upgrade to 9.2 - Manual merge wo-card-group.delta.xml to wo-card-group.xml
  • 1.  Upgrade to 9.2 - Manual merge wo-card-group.delta.xml to wo-card-group.xml
    Posted 06-16-2026 09:38
    I successfully manually merged our 9.0.21 wo-card-group.delta.xml changes to the new 9.2 wo-card-group.xml file without any warnings or errors. however, when I attempt to preview, I see the following errors below. Any idea how to resolve these errors?
    1) [ERROR]: Failed processing the MAML file with error 'Unknown slot 'slot10' is defined, but not used in parent element.'
    2) ID-Processor - [ERROR]: ID '{'qj_43[' + props.index + ']'}' must begin with a letter between a-z and can only contain alphanumeric characters or underscore '_': '{'qj_43[' + props.index + ']'}', detected in element: date-relative '{"id":"{'qj_43[' + props.index + ']'}","text-prefix":"Due","type":"date_full_month","value":"{item.schedfinish}","_originalId":"qj_43"}'
    MARK FRITZ
    GM
