 Not able to start MAS Db2u Pod
  • Infrastructure
Vincent Yap's profile image
Vincent Yap posted 04-09-2025 02:31
Hi Experts,
Our Db2 pod for our MAS9 dev instance is not running. We are unable to log into the terminal.
Per checking MAS Workspace JDBC connection we are getting error below:
Message: JDBC configuration was unable to be verified: connection error msg: [IBM][CLI Driver] SQL30081N A communication error has been detected. Communication protocol being used: "TCP/IP". Communication API being used: "SOCKETS". Location where the error was detected: "172.30.54.120". Communication function detecting the error: "connect". Protocol specific error code(s): "111", "*", "*". SQLSTATE=08001 SQLCODE=-30081 --- statement error msg: --- exception msg: [IBM][CLI Driver] SQL30081N A communication error has been detected. Communication protocol being used: "TCP/IP". Communication API being used: "SOCKETS". Location where the error was detected: "172.30.54.120". Communication function detecting the error: "connect". Protocol specific error code(s): "111", "*", "*". SQLSTATE=08001 SQLCODE=-30081
We also check the StatefulSet of the Db2u pod and is in Init:0/2 status.
Tinnokesh AP's profile image
Tinnokesh AP
Hi Vincent,
This is due to connectivity/communication failure to database, which may be due to availability of the resource. Could you check whether all DB/MAS related pre-requisites are in place.
