  • 1.  Time-Based PMs not Triggering properly - is the PM Forecast responsible?
    Posted 01-09-2024 15:00
    We have some cases recently where the time-based PMs are not triggering properly - namely, they're creating work orders early.  When looking at the Earliest Next Due Date, I can see that it's incorrect, but the only way I've found to change it is by changing the frequency units temporarily and then changing them back again.
    This problems seems to have started when we started using the PM forecast on a regular basis, so I'm suspicious here.  We're NOT using the PM forecast to set the next due date, so it shouldn't be related, but I'm not sure about this.  It seems to me we had a problem like this a few years ago when we tried to use the PM forecast before.  We stopped using PM forecasting, and only started using it again recently.
    Maximo version:  7.6.0.9
    If anyone has any insight into this, I'd appreciate it.
    Thanks.
    Shannon Rotz
    InComm Solutions Inc.
  • 2.  RE: Time-Based PMs not Triggering properly - is the PM Forecast responsible?
    Posted 01-11-2024 00:56
    Hi Shannon
    PM Forecast will only show you dates when PM will generate a Work Order and WO is generated PM Forecast instance will be deleted for that date. Though you can check couple of things in this regards-
    1. Check if New Date was updated on PM Forecast which has generated WO early on such PM. New Date allows you to modify the date of WO generation if you don't want it to happen on due date due to some reason.
    2. Check for Lead Time on PM Record and see it is not set to generate PM WO early.
    3. Check for Lead Time on PM Options under Organization select action- There is also a field available to get Lead Time to be used by PM WO Gen Cron task.
    Hope you'll be able to find out the cause with these steps. Other suggestion will be to use feature of Locking Forecast Dates on PM by Select Action. This will also ensure that some user doesn't modify it w/o knowing the impact.
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: Time-Based PMs not Triggering properly - is the PM Forecast responsible?
    Posted 01-14-2024 17:49
    Hi Shannon,
    There is some key information left out.  Namely, are the PM's meter or day-based?
    That said, when you're using the PM forecast, the PM generation now uses that information.  There are some great articles by Andrew Jeffery see Maximo Secrets and there is information from IBM using this link.
    In essence, it takes over when the PM is to generate based on the forecast date.
    There are rules around when a forecasted date is calculated, and it may be that you've not noticed that the forecasted date is different to the earliest due date.
    For both types of PM have you set the generate ahead by (or leadtime).  Remember this says to the system to decrease the interval when the PM is generated.  Note, that this does not affect the target start date of the PM, it's just that you've said "I need 10 days before working on the PM to schedule and organise materials (or the like)".
    For meter-based PMs it is recommended that you delete and regenerate the forecast regularly (i.e. daily) as the meter average units vary each time the reading is taken.  We've found that it is very important to delete, and then regenerate because it doesn't seem to reforecast if there are existing dates.  There are a couple of cron tasks to assist with this.
    I would also recommend turning on eAudit on the PM and PMMETER tables as this has helped many times when there have been questions like yours as it captures the state of the PM.
    I happy to have a chat if needed.
    Principal Consultant
    COSOL
    #IBMChampion
  • 4.  RE: Time-Based PMs not Triggering properly - is the PM Forecast responsible?
    Posted 01-29-2024 13:38
    Hi Craig:  thanks for the info on forecast.  I've been dealing with PMs for quite a while, but the forecasting functionality is newer and for one reason or another (mostly because we weren't using it), I hadn't looked very deeply into the nuances of it.  I'll talk to the users about whether they want to generate the forecast manually at need, and the need to delete it if so.
    Regarding lead time - I'm having another issue with that, but I'll post in a separate thread.
    Shannon Rotz
