  • 1.  Maximo Intermittent Reload Issue
    Posted 01-10-2024 02:25
    Hi Team ,
    We are facing intermittent reload issue in production instance
    The browser cannot connect to to the server. Reload the application and try again. If reloading does
    not solve the problem, the reason might be that you are disconnected from the network
    or the server might be down. Error code: 0
    Checked the following
    1.Network Issue---All OK
    2.Firewall Issue - All OK
    3.Use Persistent Keep Alive Checked.
    4.No relevant messages found in Application Server /Database Logs
    Any Suggestions/inputs please
    Swapna
    Swapna Shimpi
    DXC
  • 2.  RE: Maximo Intermittent Reload Issue
    Posted 01-11-2024 00:59
    Not sure if there can be a straight forward answer of what is causing it as it need check of multiple things.
    Below tech note provides the write. up from IBM explaining how to approach the problem which can be good start, You can also open PMR with IBM to help with further diagnosis.
    https://www.ibm.com/support/pages/maximo-communication-problem-server-prompting-reload
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: Maximo Intermittent Reload Issue
    Posted 02-29-2024 09:26
    Hi Swapna
    We identified same issue and for end users the most annoying effect was that entered and not saved data was lost. After investigations we learned that system property mxe.webclient.lostconnectionwarningonly may help here. Setting this to TRUE does not fully remove message but replaces Error message with warning box. Also in this case data was not lost. You could try if this helps in your case.
    There are also two other time interval related properties starting with mxe.webclient.lostconnection which may affect the behaviour.
    Johan Svart
Featured Podcast
Watch the Podcast
Watch the latest episode
